16 years agoWaveform simulation no results!
VHDL code is not wrong ,but when i create do not get the results of simulation waveform file.somewhere i malke a mistake !! can you help me ?
library ieee; use ieee.std_logic_1164.all; entity counter10 is port (clk: in std_logic; digit : out std_logic ); end counter10 ; architecture counter10 of counter10 is begin process (clk) variable temp:integer range 0 to 10; begin if(clk'EVENT AND clk='1')then temp:= temp+1; if (temp=10)then temp:=0; end if ; end if ; end process; end counter10 ;2 Replies
no , i thinlk it's output port .need assign value ?o i try it again . than you !
Do you assign any value to the output port digit?
