14 years agoWatchdog doesn't start
Hallo, I try to use the WD component in my Qsys system. In general a very simple thing I thought. - Add to system with a defined timeout period - generate / build all - start wd --> it ru...
14 years agoI'm having the same issue. The problem seems to be that the top-level qsys verilog file (suggested in alteras watchdog fix) should not be edited and is overwritten by the system every compile... how can this be done?
