Watchdog Disable new SOC EDS Flow
- 3 years ago
Hi Robert,
You can disable the watchdog from uboot using the new flow, the details in the github
https://github.com/altera-opensource/u-boot-socfpga
follow the build u-boot step in building bootloader
- Watchdog:
CFG_SYS_WATCHDOG_FREQ
Some platforms automatically call WATCHDOG_RESET()
from the timer interrupt handler every
CFG_SYS_WATCHDOG_FREQ interrupts. If not set by the
board configuration file, a default of CONFIG_SYS_HZ/2
(i.e. 500) is used. Setting CFG_SYS_WATCHDOG_FREQ
to 0 disables calling WATCHDOG_RESET() from the timer
interrupt.
You can use this step to disable the watchdog
Thank you,
Aliff
Hi Robert,
Thanks for the update, , I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Aliff
