16 years agoWarnings in Quartus
I have a system in which I am attempting to run program code from sdram on a DE2 board. I get the following warnings after quartus compilation. Warning: Output pins are stuck at VCC or GND Wa...
16 years agoYou read the warning :
"Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "SDRAM_cke" is stuck at VCC" Maybe this is exactly what you want. Did you put the SDRAM_cke signal stuck to '1' in order to permanently enable the SDRAM? If so this is a warning that you can ignore. Sorry but I cannot help for the rest.
