17 years agoWarning message while design compile
Does anyone know how to get rid of the following message?
warning (10542): vhdl variable declaration warning at altera_europa_support_lib.vhd(340): used initial value expression for variable "arg_copy" because variable was never assigned a value Thanx for every notice!!6 Replies
arg_copy is part of the libary:
-- a_ext is the Altera version of the EXT function. It is used to both -- zero-extend a signal to a new length, and to extract a signal of 'size' -- length from a larger signal. FUNCTION a_ext (arg : STD_LOGIC_VECTOR; size : INTEGER) RETURN STD_LOGIC_VECTOR IS VARIABLE arg_copy : STD_LOGIC_VECTOR ((arg'length - 1)DOWNTO 0) := arg ; VARIABLE result : STD_LOGIC_VECTOR((size-1) DOWNTO 0) := (others => '0'); VARIABLE i : integer := 0; VARIABLE bits_to_copy : integer := 0; VARIABLE arg_length : integer := arg'length ; VARIABLE LSB_bit : integer := 0; BEGIN bits_to_copy := a_min(arg_length, size); FOR i IN 0 TO (bits_to_copy - 1) LOOP result(i) := arg_copy(i); end LOOP; RETURN(result); END; - Altera_Forum
it was just a funny statement. :)
there are some companies that are very strict about Warning messages during compilation for their products. - Altera_Forum
Don't get me wrong. I like my managers, they are under more pressure from those fat cats. But what I don't understand is why they always walk in pairs?
--- Quote Start --- I wouldn't care as long as things work and keep managers off my shoulder. --- Quote End --- i enjoyed this post. :D - Altera_Forum
With sopc and other automated code generations I get tons of warnings...
I wouldn't care as long as things work and keep managers off my shoulder. - Altera_Forum
hmm...I have never seen that before, is 'arg_copy' one of your design variables or is it a part of the altera lib file ??
