14 years agoWarning: Found 20 output pins without output pin load capacitance assignment?
What is the method to find this info? Rough estimates usually adequate?
Where do these numbers go into Quartus?2 Replies
I got the same warning, because the default cap load is 0pF for the pin output type you have specified. If you go to the Assignments/Device... tab and click on the "Device and Pin Options..." button, you will find "Capacitive Loading" under Category:. Here you can set the default load cap for the output driver type in your design.
I find this useful for output timing analysis. It will also help you choose the minimum output drive strength to meet your desired output timing. - Altera_Forum
Unless you have a very timing-critical design, I believe this is one of the MANY Quartus II compilation warning messages that you can ignore. At least until you get down to the final optimization of the design.
Anyone else have comments on this?
