17 years agoWarning (14130)
I am getting this type of warning while synthesizing the design.. any suggestion/advice??? warning (14130): reduced register "buf_reg[13][0]" with stuck data_in port to stuck value vcc2 Replies
Yes It is always tied to High, thanks for your replay
It means that whatever logic you have on the input to the register named BUF_REG[13][0] always generates a '1' value. Therefore there is no point in adding a register and Quartus deletes it.
You need to check the logic driving that register bit. Hope this helps
