17 years agoWarning (14130)
Hi, I am getting this type of warning while synthesizing the design.. any suggestion/advice??? warning (14130): reduced register "buf_reg[13][0]" with stuck data_in port to stuck value vcc
17 years agoIt means that whatever logic you have on the input to the register named BUF_REG[13][0] always generates a '1' value. Therefore there is no point in adding a register and Quartus deletes it.
You need to check the logic driving that register bit. Hope this helps
