19 years agoVref power source?
I’m trying to decide if I can get away with a simple voltage divider for my vref pins. Any advice?
19 years agoI’ve got some advice, use a regulated power supply, not a voltage divider. When you use a voltage divider, the resistors would have to be precisely matched and have a very tight tolerance. If they are not matched exactly, then your reference voltage may vary at the device input pin, and that will lead to signal level detection issues. It’s worth the extra money and board space if you want a robust interface.
