9 years agoVoltage level issue on MAX10
Hello, i'm trying to test my MAX10 using clock of 1MHz on some pins. one of the HW pins is not output the signal as expected, the clock goes high to 3.3v and then down to 1.6v instead of 0v. t...
9 years ago --- Quote Start --- How good is your oscilloscope? Or, more importantly, your scope probe. What bandwidth do they have and what loading is your probe adding to your circuit? If the bandwidth is not 'enough', or the probes load too high, it's going to result in a very good looking waveform with reduced amplitude. To look at a 150MHz clock with any confidence I'd suggest you need at least 1GHz bandwidth on scope and probe. Cheers, Alex --- Quote End --- Thanks for the suggestion... That was it...go to a faster Oscope...
