9 years agoVoltage level issue on MAX10
Hello, i'm trying to test my MAX10 using clock of 1MHz on some pins. one of the HW pins is not output the signal as expected, the clock goes high to 3.3v and then down to 1.6v instead of 0v. t...
9 years agoWhat else is connected to this pin - what's loading it?
Everything you've stated looks fine. Given you're using 3.3V LVCMOS, you can ignore the DIFFIO function of the pin. Cheers, Alex
