16 years agoVIP Suite Scaler; Bad Status Value and Strange Mixer Behaviour
Hello All,
I'm having trouble with my scaler. I'm using the SoPC builder in Quartus 9.1: RGB(4:4:4) Progressive SXGA (1280x1024) 60Hz Parrallel TTL -> CVI -> Scaler (Nearest N.) -> FB (DDR2 w/Pipeline Bridge) -> Mixer -> CVO -> SVGA 24bit Parallel TTL. The background layer for the Mixer is a Test Pattern Generator. The Scaler and Mixer have control ports enabled which are being controlled by a Nios executing from internal M9K RAM. The whole path is clocked with the pixel clock (110MHz) of the incoming video, but I run it through a PLL first (1:1) for some jitter correction - is this a good idea? (seems to look ok.) I have had two problems: 1) on some builds the mixer appear to work, but the scaler status register reads 0xffff ffff. if i remove the control port from the scaler, the system works (mixer controllable).2) on some builds i can't set the go bit of the mixer, this will typically be accompanied by a status read of 0xffff ffff from the scaler status register. Note that without control (i.e. a mixer) the path works well; so I'm assuming that there is no buffer overflow from the CVI and that the fb is functional. I find the scaler register read disturbing; this makes me think that I'm not reading valid memory and that the scaler is not getting the GO command either. To that end I checked the memory address allocation, and I'm using: 0x0000 0000 - 0x01ff ffff - DDR2 0x0200 0000 - 0x03ff ffff - pipeline bridge 0x0400 0000 - everything else Also note that when I use the SoPC builder command 'automatically assign base addresses' it tries to put 'everything else' starting at 0x0, i.e. over the top of the DDR2 range. Is that ok? I'd have thought that DDR2 is only accessible through the pipeline bridge... but I wouldn't be suprised... I'd love to hear back from anyone with any perspective, my head is getting very sore and there's now a crack in the wall where I've been banging it... Thanks in advance, Brent.
