16 years agoVIP Suite Scaler; Bad Status Value and Strange Mixer Behaviour
Hello All, I'm having trouble with my scaler. I'm using the SoPC builder in Quartus 9.1: RGB(4:4:4) Progressive SXGA (1280x1024) 60Hz Parrallel TTL -> CVI -> Scaler (Nearest N.) -> FB (DDR...
16 years agoLooks like timing is an issue. Yesterday using the 'Classic Timing Analysis Wizard' I managed to get the video path working again without flicker or failure and even hooked up control to the CVO - it still doesn't look as good as the one I compiled under Quartus 9.0, but there could be other factors at play.
I'll do the coursework you've prescribed and try it again with TimeQuest. Thanks again, Brent.
