16 years agovideo tracker EU PAL
In your opinion is Possibility to analyze a video pal and get the x and y offset of an object relative to the center of the screen? i'm using cycloneII fpga
16 years agoIf you have a static camera it can be quite trivial:
Static image - current image = changes in the image, which are usually targets. The hard part is then finding and tracking the targets. It can require quite a bit of memory. You will need external memory for the frame buffering. The solutions Ive seen use a processor and FPGA. The FPGA does the image pre-processing with the processor taking the thresholded image and tracking the targets.
