14 years ago
VHDL syntax Help
Hi Folks, I am relatively new to this VHDL lark and I have a quick question which I suspect is rather simple when you know how. I wish to code the following:
val1 is a STD_LOGIC_VECTOR(31 downto 0)
val2 is a STD_LOGIC_VECTOR(31 downto 0)
val3 is a STD_LOGIC_VECTOR(7 downto 0)
I wish to subtract val2 from val1 and put the result in val3. i know that the result will always be 8bit:
so i need something like:
val3 (7downto 0) <= STD_LOGIC_VECTOR(unsigned(val1(31 downto 0) - unsigned(val2(31 downto 0));
Now i know i need to 'slice the arithmetic operation as it gives me a 31 downto 0 size result, but where do i do the 'cast/slice' down to the correct width? I have tried a few arrangements and cant seem to get it right!
many thanks in advance
de Boogle
    Thanks the thread was perfect, i couldn't find this when i was looking around!
    As shown in a recent thread, Quartus 12 supports a special syntax where you append a slice specification to the conversion function, please review the discussion. IMHO it's not based on specified VHDL syntax and should be used with care.
    http://www.alteraforum.com/forum/showthread.php?t=37199
    The regular VHDL way to use an auxilary signal/variable is also discussed in the thread.
