15 years agoVHDL String to std_logic_vector conversion
I'm trying to add some comments into my Modelsim wave files, and I realized that Modelsim can display a std_logic_vector as a text string. I've looked around for packages but haven't found anything. ...
15 years agoI think I know what chipslinger wants, I have done similar things to send text in a packet and have the simulator (the internal simulator in my case) or Signaltap display the std_logic_vector as ASCII.
I wrote a to_std_logic_vector() function that accepts a string argument and returns a std_logic_vector.
function to_std_logic_vector( s : string )
return std_logic_vector
is
variable r : std_logic_vector( s'length * 8 - 1 downto 0) ;
begin
for i in 1 to s'high loop
r(i * 8 - 1 downto (i - 1) * 8) := std_logic_vector( to_unsigned( character'pos(s(i)) , 8 ) ) ;
end loop ;
return r ;
end function ; You may have to reverse the string first depending on your 'endianness likings':
function reverse( s : string )
return string
is
variable r : string(s'high downto s'low) ;
begin
r(s'high + 1 - i) := s(i) ;
end loop ;
return r ;
end function ;
