VHDL's avatar
VHDL
5 years ago
VHDL simulation using modelsim software
Dear Technical team,
Developed test program for switch IC using VHDL and simulated with modelsim software. Result is in the 'Z' state .
Kindly support me to solve this issue..
please find the below for VHDL model of switch IC ,
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY EN_DG221 IS
PORT (
lblEN : IN STD_LOGIC;
lblA1 : INOUT STD_LOGIC;
lblY1 : INOUT STD_LOGIC
END EN_DG221;
ARCHITECTURE ARCH_EN_DG221 OF EN_DG221 IS
BEGIN
lblY1<= lblA1 when lblEN ='0' else 'Z';
END;
Kalidasan G,
IC Model development Team,
  • sstrell's avatar
    sstrell
    It's not clear whether you're trying to create a tri-state output or a bidirectional I/O. Your ports are bidirectional, but your logic is for a tri-state output.
    If it's supposed to be a tri-state, lblY1 should be an out, not inout.
  • Hello VHDL
    Thank you for posting on the Intel️® communities. We will move your question to the correct sub forum, for future FPGA requests please post under FPGAs and Programmable Solutions
    David G
    Intel Customer Support Technician
