15 years ago
VHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board
In the project I need to build a robot.
My first step was to design a ASM and from that to take out the FSM which i did (hopefully I did it good enough)
The second step is to check one of my ASM and I choose my engine control ASM
I wrote a program in VHDL using quartus and burn it into my board
Instead of using the motors from the beginnig the idea was to used the board's led using a PWM generator that will create a "running led" effect for a curtain direction and in change it in a push of a button
but it didn't work.
Can anybody tell me what I did wrong?
I think it's in the pin assignment
    I attaching me designs just in case they are a bit different by now but they could deliver the general idea
    --- Quote Start ---
    but it didn't work.
    --- Quote End ---
    Hi there
    I am very new in VHDL I want to write a code for line following robot , but I faced a lot of problems because I started from zero. I spent already more than two months to learn it.
    when I started to write the code I got stuck and I couldn't know how to start.
    I tried to check from the internet but I didn't find any thing, then I found your code for robot using VHDL. could you please help me with that if you have done it successfully
    I can't really help you if I don't know what went wrong with your code
    I can tell you the steps that I had made in order to create a working code
    1. Understand your goals
    2. Pick your components according to your goals
    3. Understand how the components works
    4. Create asm
    5. Design a logic circuit
    6. Write it in vhdl
    Hope it was helpful
