15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years agoHii again
the code has changed (add generic and a constant) and I am using the modelsim now insted of the active hdl but I still don't see any waves in the simulation :mad:
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
Entity Pwm is
generic (
DC : time:=1 ms;
clock_period: time:=20 ns
Port ( Rst : In std_logic;
Clk : In std_logic;
Sw : In std_logic_vector (2 downto 0);
Enable : in std_logic;
Led : buffer std_logic_vector (7 downto 0);
Pwm : Out std_logic
attribute altera_chip_pin_lc: string;
attribute altera_chip_pin_lc of Clk : signal is "@N2";
attribute altera_chip_pin_lc of Rst : signal is "@G26";
attribute altera_chip_pin_lc of Led : signal is "@AE23, @AF23, @AB21, @AC22, @AD22, @AD23, @AD21, @AC21";
attribute altera_chip_pin_lc of Sw : signal is "@N25,@N26, @P25";
attribute altera_chip_pin_lc of Enable: signal is "@AE14";
end entity Pwm;
Architecture arc_Pwm of Pwm is
constant duty_cycle: integer:=DC/clock_period;
signal Counter : std_logic_vector (16 downto 0);
begin
PwmReg: process (Clk,Rst,Sw)
begin
if (Rst='1') then
Counter <= (others=>'0');
Pwm <='0';
Led <= (others=>'0');
elsif rising_edge(Clk) then
if (Enable='1') then
if (Counter = duty_cycle) then
Counter <= (others => '0');
if (Sw(0) = '1') and (Sw(1) = '0') and (Sw(2) = '0') then
led <= led + 1;
elsif (Sw(0) = '0') and (Sw(1) = '1') and (Sw(2) = '0') then
led <= led - 1;
end if;
else
Counter <= Counter + 1;
end if;
end if;
if (Counter < duty_cycle) then
Pwm <= '1';
else
Pwm <= '0';
end if;
end if;
end process PwmReg;
end architecture arc_Pwm;
library ieee;
use ieee.std_logic_1164.all;
--use std.textio.all;
--use ieee.std_logic_textio.all;
entity tb_pwm is
end entity tb_pwm;
architecture arc_tb_pwm of tb_pwm is
signal Clk : std_logic := '0'; --
signal Rst : std_logic := '0'; --
signal Sw : std_logic_vector (2 downto 0):= "000"; --
signal Enable : std_logic := '0'; --
signal Pwm : std_logic; --
signal Led : std_logic_vector(7 downto 0); --
begin
test : entity work.pwm
port map (
Clk => Clk,
Rst => Rst,
Enable => Enable,
Sw => Sw,
Pwm => Pwm,
Led => Led );
Clk <= not Clk after 10 ns;
process
begin
wait until rising_edge(Clk);
--wait on switch push;
Enable <= '1';
-- l1 : loop
wait until rising_edge(clk);
--wait for 1 ns;
Sw(0) <= '1';
Sw(1) <= '0';
Sw(2) <= '0';
wait for 0.025us;
Sw(0) <= '0';
Sw(1) <= '1';
Sw(2) <= '0';
wait for 0.025us;
Sw(0) <= '0';
Sw(1) <= '0';
Sw(2) <= '1';
wait for 0.025us;
Enable <= '0';
wait for 0.025us;
Rst <='0';
wait for 0.025us;
end process;
end architecture arc_tb_pwm;
In the do file I wrote 1us and in the tb iwrote 0.025us in order to see it in the simulaton thanks in advance
