15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years agoYour right I changed the code a little.
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
Entity Pwm is
Port ( Rst : In std_logic;
Clk : In std_logic;
Sw : In std_logic_vector (2 downto 0);
Enable : in std_logic;
Led : out std_logic_vector (7 downto 0);
Pwm : Out std_logic);
attribute altera_chip_pin_lc: string;
attribute altera_chip_pin_lc of Clk : signal is "@N2";
attribute altera_chip_pin_lc of Rst : signal is "@G26";
attribute altera_chip_pin_lc of Led : signal is "@AE23, @AF23, @AB21, @AC22, @AD22, @AD23, @AD21, @AC21";
attribute altera_chip_pin_lc of Sw : signal is "@N25,@N26, @P25";
attribute altera_chip_pin_lc of Enable: signal is "@AE14";
end entity Pwm;
Architecture arc_Pwm of Pwm is
signal Counter : std_logic_vector (16 downto 0);
signal DC : std_logic_vector (16 downto 0);
signal Rd_led : std_logic_vector (7 downto 0);
begin
PwmReg: process (Clk,Rst,Sw)
begin
if (Rst='1') then
Counter <= (others=>'0');
Pwm <='0';
Led <= (others=>'0');
Rd_led <= (others=>'0');
DC <= conv_std_logic_vector(32678,17); --duty cycle 50%
elsif rising_edge(Clk) then
if (Enable='1') then
if (Counter = 50000) then
Counter <= (others => '0');
if (Sw(0) = '1') and (Sw(1) = '0') and (Sw(2) = '0') then
Rd_led <= Rd_led + 1;
elsif (Sw(0) = '0') and (Sw(1) = '1') and (Sw(2) = '0') then
Rd_led <= Rd_led - 1;
end if;
Led <= Rd_led;
elsif (Counter < DC) then
Counter <= Counter + 1;
Pwm <= '1';
else
Pwm <= '0';
end if;
else
Pwm <= '0';
end if;
end if;
end process PwmReg;
end architecture arc_Pwm;
I am don't know what numeric std library does can you clarify please, and why is it better to use rather then std_logic in general and specific in this code
