15 years agovhdl querry
Hello Friends,
I am new to VHDL and I have a couple of querries. Kindly help me out if possible - 1) If-else loop in VHDL. Now, what I understand is that VHDL code is synthesised into hardware (gates/mux..etc) using a synthesizer. How is an if-else loop created in hardware? The -f-else is a sequential statement. Will it run/be executed at the same clock cycle or the next ? For eg - in the code shown write_req <= '1'; write_req:process(phy_clk) begin if rising_edge(phy_clk) then if reset_phy_clk = '1' then write_req_1 <= '0'; write_req_2 <= '0'; else write_req_1 <= write_req; write_req_2 <= write_req_1; end if; end if; end process p_data_req; After how many cycles is write_req_2 asserted ? Can anyone kindly explain this pls? Also, can if-else statements be used to generate/synthesize combinational circuits or only sequential ? Can anyone point me to a doc which shall explain in details how vhdl code is executed(order of execution/timing) and also how it is mapped into hardware ? 2) What is a latch ? fifo_o_addr_temp <= fifo_o_addr when fifo_o_addr_temp /= fifo_o_addr else fifo_o_addr_temp; Will doing the above action create a latch ? How so? Is creating a latch in code a good practise or bad? Regards, Vinod Karuvat.11 Replies
Look at sensitivity-list topic in VHDL textbook.
DFF is edge sensitive. LATCH is level sensitive.
