15 years agoVHDL Numeric Type Conversion
I am using a bunch of variables to do some math. These variables, X and Y coordinates, are converted to different numeric types for ease of math operations. The outputs, Xm and Ym, are SLV's and depe...
15 years agothe fact you are doing post synthesis simulation probably explains why they are not working. Quartus is probably converting everything to a signed number during synthesis, or you are showing them in the simulator as signed when actually they are unsigned.
--- Quote Start --- I do know the difference b/t variables and signals. I wanted to use variables because they don't represent HW and I don't have to wait for the clock to change them. --- Quote End --- This shows you clearly do not understand variables. Just because they are updated immediatly does not mean they do not represent hardware. At the very least, variables may represent a wire between one register to the next. And in some circumstances they can be used to instantiate anything a signal can. Consider the following two bits of code. The first one has a single register between the input and output.
process(clk)
variable v : std_logic;
begin
if rising_edge(clk) then
v := input;
output <= v;
end if;
end process;
Now this code:
process(clk)
begin
output <= v;
v := input;
end if;
end process;
Now v represents an additional register in the pipeline, so there are 2 registers between the input and output instead of just 1.
