15 years agoVHDL Numeric Type Conversion
I am using a bunch of variables to do some math. These variables, X and Y coordinates, are converted to different numeric types for ease of math operations. The outputs, Xm and Ym, are SLV's and depe...
15 years ago --- Quote Start --- Yes, because they are variables. You can use signals to make them visible. My previous comment about d1 to d4 is still valid, I fear. To ask explicitely: how do you load the values for d1 to d4? May be, but you possibly don't understand the side-effects of implicite type conversion during assignment. I think, this previous suggestion is quite reasonable. --- Quote End --- I do know the difference b/t variables and signals. I wanted to use variables because they don't represent HW and I don't have to wait for the clock to change them. I did try using signals before posting this thread, and got even more unexpected simulation results. But I haven't tried using signals since changing them all to integers. I'll give this a try. Here's how I load the values for d1 to d4: --- dst1, dst2, dst3, dst4 : in integer range 0 to dst_max; valid1, valid2, valid3, valid4 : in std_logic; ... if valid1 = '1' then d1 := dst1; -- same for d2, d3, d4 --- I already stated that I changed all my variables to type integer. So the only type conversion I am doing is for the outputs Xm and Ym: Xm <= std_logic_vector(to_signed(-Xc, 20)); There are no type conversions for Xp and Yp, but they are incorrect. If there's a problem w/ d1 to d4, why are Xm and Ym correct, though I had to type convert Xc and Yc?
