15 years agoVHDL Numeric Type Conversion
I am using a bunch of variables to do some math. These variables, X and Y coordinates, are converted to different numeric types for ease of math operations. The outputs, Xm and Ym, are SLV's and depe...
15 years agoI am doing a post-synthesis timing simulation using Quartus 9.1 native simulator.
I changed my d# variables from type natural to (unsigned) integer. They represent distances, so cannot be negative. I got rid of the intermediary variables Xc_* and Yc_*, but kept Xm and Ym as output SLVs. But I still get the same results: d1 = 1955, d2 = 300000, d3 = 158100, d4 = 23456 Xp should be -138272, but is 430016 Yp should be 78072, but is -369448 Xm is 138272 (correct) Ym is -78072 (correct) Xc* and Yc* could not be displayed by the simulator Here's my revised code snippet: --- generic(dst_max : positive := 300000); ... Xm, Ym : out std_logic_vector(19 downto 0); ... variable d1, d2, d3, d4 : integer range 0 to dst_max; variable Xc, Yc, Xc1, Yc1, Xp, Yp : integer range -dst_max to dst_max; ... Xc1 := (d4 - d2); Xc := Xc1/2; ... Yc1 := (d3 - d1); Yc := Yc1/2; ... Xp := Xc; -- update previous center Yp := Yc; Xm <= std_logic_vector(to_signed(-Xc, 20)); -- move back to center Ym <= std_logic_vector(to_signed(-Yc, 20)); --- I don't understand how Xp and Yp have the unexpected simulation values while Xm and Ym have the correct simulation values, when both are representations of Xc and Yc.
