14 years agoVHDL Math Real & Quartus
I've been using the VHDL package ieee.math_real to declare parameters, the idea being to condense as much information in a design file as possible. in particular, for fixed point operations in feedba...
14 years agoThanks for the feedback everyone . . . However, the RecipFactor if made a constant still gives a message, when synthesizing the VHDL module shown below:
Warning (10542): VHDL Variable Declaration warning at math_real.vhd(2373): used initial value expression for variable "RECIPROCAL" because variable was never assigned a value As mentioned, this is what I was trying to avoid. In the code below, the constant RecipSqrt3 is clean; no messages are reported by Quartus at compile time. Best, James --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use ieee.math_real.all; entity IFBscale is port( MCLK : in std_logic; HRST : in std_logic; START : in std_logic; IA : in std_logic_vector(15 downto 0); IB : in std_logic_vector(15 downto 0); ALPHA : out std_logic_vector(15 downto 0); BETA : out std_logic_vector(15 downto 0); ScaleFactor : in std_logic_vector(15 downto 0); DONE : out std_logic ); end IFBscale; architecture RTL of IFBscale is constant N : integer := 16; constant N2 : integer := 32; signal factor : real; constant RecipFactor : real := ROUND((2.0**15)*(1.0/SQRT(3.0))); constant RecipSqrt3 : std_logic_vector(N-1 downto 0) := std_logic_vector(to_signed(integer(real(ROUND((2.0**15)*(0.577350269189626)))),16)); signal betax : std_logic_vector(2*N-1 downto 0); type baseDataType is record x : signed(N-1 downto 0); done : std_logic; slv : std_logic_vector(N*2-1 downto 0); slvN : std_logic_vector(N-1 downto 0); end record; signal ias,ibs,sum : baseDataType; signal donex : std_logic; signal betay : signed(N-1 downto 0); begin /*---------------------------- Register Outputs ----------------------------*/ oReg: process(all) begin if HRST then ALPHA <= (others => '0'); BETA <= (others => '0'); DONE <= '0'; elsif rising_edge(MCLK) then ALPHA <= std_logic_vector(ias.x); if donex then BETA <= std_logic_vector(betax(N2-2 downto N-1)); DONE <= '1'; else DONE <= '0'; end if; end if; end process oReg; /*---------------------------- Scale IA ----------------------------*/ Umult1 : entity work.signed_mult2(rtl) generic map(arg_size => N) port map( CLK => MCLK, HRST => HRST, START => START, DONE => ias.done, a => IA, b => ScaleFactor, result => ias.slv ); /*---------------------------- Scale IB ----------------------------*/ Umult2: entity work.signed_mult2(rtl) generic map(arg_size => N) port map( CLK => MCLK, HRST => HRST, START => START, a => IB, b => ScaleFactor, result => ibs.slv ); ias.x <= signed(ias.slv(N2-3 downto N-2)); ibs.x <= signed(ibs.slv(N2-3 downto N-2)); process(all) begin if HRST then sum.x <= (others => '0'); sum.done <= '0'; elsif rising_edge(MCLK) then if ias.done then sum.x <= X"0000" - ias.x - shift_left(ibs.x,1); sum.done <= '1'; else sum.done <= '0'; end if; end if; end process; sum.slvN <= std_logic_vector(sum.x); /*---------------------------- Scale Ibeta by1/sqrt(3) ----------------------------*/ Umult3: entity work.signed_mult2(rtl) generic map(arg_size => N) port map( CLK => MCLK, HRST => HRST, START => sum.done, DONE => donex, a => sum.slvN, b => RecipSqrt3, result => betax ); end RTL; --- Quote End ---
