14 years ago[VHDL] integer to std_logic or std_logic_vector conversion
Hello, I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as intege...
14 years agoI'm using Cadence NC-VHDL actually... No station with Quartus free right now...
About my process, here is the actual version :
conv : PROCESS
VARIABLE reset_hwTemp : unsigned(31 downto 0);
VARIABLE reset_hwVar : std_logic;
VARIABLE wdogInitDelayVar : std_logic_vector(15 downto 0);
BEGIN
if rst_n='0' then
reset_hwVar := '0';
reset_hw_o <= '0';
reset_hwTemp := (others=>'0');
wdogInitDelayVar := (others=>'0');
wdogInitDelay_o <= (others=>'0');
WAIT until rst_n='1';
else
-- Cast an integer to an unsigned on 1 bit and cast it again to std_logic
--print("Integer read : " & str(reset_hw_i));
reset_hwTemp := to_unsigned(reset_hw_i, 32);
reset_hwVar := reset_hwTemp(0);
--print("std_logic_vector " & str(reset_hwVar));
--reset_hw_o <= reset_hwVar;
-- Cast an integer to an unsigned on 16 bit and cast it again to std_logic_vector
--wdogInitDelayVar := std_logic_vector(to_unsigned(wdogInitDelay_i, 16));
--print("Integer read : 0x" & str(wdogInitDelay_i, 16));
--print("std_logic_vector 0x" & hstr(wdogInitDelayVar));
--wdogInitDelay_o <= wdogInitDelayVar;
WAIT until rst_n='1'or (clk'event and clk='1');
end if;
I still have a problem with the line
reset_hwTemp := to_unsigned(reset_hw_i, 1);
I've the following error :
range constraint violation If needed, I can always use an if statement on the binary integer to produce std_logic signals, something like
IF int_bin=0 THEN
std_log <='0';
ELSEIF int_bin=1 THEN
std_log <='1';
ELSE
assert FALSE
report "wrong input"
About the second part of the process, I'll try to use the following statement...
wdogInitDelayVar := to_unsigned(wdogInitDelay_i, 16)(15 downto 0);
