14 years agoVHDL integer causing RTL and Gate level simulation difference
I have a general question regarding the use of integers in VHDL. If I have a lot of Array defined, we have to use integer as its index when accessing the arrays. However, when the index is conv...
14 years ago --- Quote Start --- Anybody know how to avoid INTEGERs when access arrays? --- Quote End --- Use conversion operators that output an integer. For example;
type rddata_mux_t is array (0 to 7) of std_logic_vector(31 downto 0);
signal rddata_mux : rddata_mux_t;
signal rddata_sel : std_logic_vector(2 downto 0);
rddata_mux(0) <= ....
rddata_mux(1) <= ....
rddata <= rddata_mux(to_integer(unsigned(rddata_sel)));
Or as Tricky comments, define a range restricted integer for rddata_sel. However, as you note, you cannot see an 'X' in that case, so using std_logic is a little more general. Cheers, Dave
