14 years agoVHDL integer causing RTL and Gate level simulation difference
I have a general question regarding the use of integers in VHDL. If I have a lot of Array defined, we have to use integer as its index when accessing the arrays. However, when the index is conv...
14 years ago --- Quote Start --- Thanks very much for the reply. My problem is exactly 'B' gets an unknown value in the design. In RTL simulation, the good 'C' values corresponding to address 0 gets used; while in Gate level simulation, the unknown 'C' gets used. When there is tons of such logic in your design and we don't do reset our flops as a general principle, it is very hard to catch which one causes the problem in gate level simulation if it is not duplicate-able in RTL simulation. In general, we don't want to give an initial value to a variable since it is ignored by the synthesize tools. What we want is to have an exact RTL simulation to avoid debugging problem using gate level simulation. --- Quote End --- What this points to then is that you may need to be writing a better testbench. The signal 'c' eventually has some effect on the overall design and it being stuck at the value contained in a(0) should have caused some output to not be correct at some point...but it can only be determined to be incorrect if you take the time to write a testbench that generates stimulus sufficient to exercise the signals and that actually checks the outputs to verify that they are correct. The time it takes to write testbenches will pay off dividends over the entire lifecycle of the code as it changes over time. However, even when you do take that time things will get missed because it can take roughly as much time to write a testbench as it does to do the design. But it can also take just a small bit of time to get a testbench that covers a lot without much effort. The value judgment comes in as to where to draw the line about where you think you've tested this enough because there will never be an end to tests that you could've written. As you've already noticed running gate level simulations are painfully slow. Many experienced designers do not run them as a simple matter of course since there time is more effectively spent elsewhere. As I mentioned in the first post, one can sometimes also write self-checking right into the design itself. It's more limited then testbench testing but has the advantage of being usable in any testbench. Kevin Jennings
