16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoProof of what I am saying, this code:
if(enable='1') then
r_reg <= r_reg + 1;
else
r_reg <=(others => '0');
end if;
Will only get executed at posedge clk NO MATTER what. And that means: adding "enable" to the sensitivity list will only confuse your code (for both humans and compilers). Besides that, when enable changes, surely there will be a clk posedge shortly after that (after all clk is a PERIODIC signal), and at that point your code WILL get evaluated (have no fear). Besides that I also know ISE tools and I know what I'm saying here :)
