16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoYes...I have connected everything. i think the way i am going to approach this problem will be the dumb way. I will let the counter run and use a d-ff to latch only the last value so the fifo only gets the largest count.
I don't know how to make counter that resets itself on an enable trigger and only provides the last count... thanks for your help though
