16 years agoVHDL Counter
I am new to VHDL, and I am trying to create a counter that will count up from 0 to X when a signal called enable will be true. I get errors like Latches are generated for incomplete case or if ...
16 years agoHola Homie,
I believe this code will do what you want. Cheers
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
Entity YourCount is
Generic( n: integer := 16);
Port(
clk : in std_logic ;
rst : in std_logic;
enable : in std_logic;
max_ticks : out std_logic;
Cnts_out : out Unsigned (N-1 downto 0)
End YourCount;
Architecture Count of YourCount is
Begin
------------- CountBe quick ---------------------------
CountBeQuick : Process(clk,rst,enable)
Variable count : integer range 0 to ((2**N)-1); -- integer range 0 to 65,535
Begin
if(rst = '1') then
count := 0; -- clear count
max_ticks <= '0'; -- clear max ticks
elsif (clk'EVENT and clk ='1' and enable = '1') then
count := count + 1;
if (count = ((2**N)-1)) then
max_ticks <= '1'; -- max_ticks stays high till reset
end if;
end if;
if (enable'Event and enable ='0') then -- this transfers count value and clears count
Cnts_out <= TO_UNSIGNED(count,N); -- converts count to unsigned of length N
count := 0;
end if;
End Process CountBeQuick;
End Count;
