15 years agoVhdl codes for 8-bit ring counter
I have VHDL codes for an 8-bit ring counter but when i try to compile it there are always errors (8 errors). I even tried editing some lines (lines 2 and 3) and compiled again and the errors reduced to 4 but the surprising thing is the corrections i made altered the conventional mode of entering the code. Although the errors were reduced to 4, I don't quite understand why that was possible.Please find below the first code and the edited code. I would really appreciate help on this. first code library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity ring_counter is port ( DAT_O : out unsigned(7 downto 0); RST_I : in std_logic; CLK_I : in std_logic ); end ring_counter; architecture Behavioral of ring_counter is signal temp : unsigned(7 downto 0):=(others => '0'); begin DAT_O <= temp; process(CLK_I) begin if( rising_edge(CLK_I) ) then if (RST_I = '1') then temp <= (0=> '1', others => '0'); else temp(1) <= temp(0); temp(2) <= temp(1); temp(3) <= temp(2); temp(4) <= temp(3); temp(5) <= temp(4); temp(6) <= temp(5); temp(7) <= temp(6); temp(0) <= temp(7); end if; end if; end process; end Behavioral; edited code library IEEE; use IEEE.ALL; use IEEE.ALL; entity ring_counter is port ( DAT_O : out unsigned(7 downto 0); RST_I : in std_logic; CLK_I : in std_logic ); end ring_counter; architecture Behavioral of ring_counter is signal temp : unsigned(7 downto 0):=(others => '0'); begin DAT_O <= temp; process(CLK_I) begin if( rising_edge(CLK_I) ) then if (RST_I = '1') then temp <= (0=> '1', others => '0'); else temp(1) <= temp(0); temp(2) <= temp(1); temp(3) <= temp(2); temp(4) <= temp(3); temp(5) <= temp(4); temp(6) <= temp(5); temp(7) <= temp(6); temp(0) <= temp(7); end if; end if; end process; end Behavioral;5 Replies
--- Quote Start --- Error (10481): VHDL Use Clause error at ringcounter2.vhd(2): design library "IEEE" does not contain primary unit "STD_LOGIC_1164" --- Quote End --- Either your Quartus installation or some global design settings are messed up. Nothing that can be seen in the code. - Altera_Forum
Thanks for your help so far.
The thing is the (edited codes) codes without the library imports compiled and had fewer errors but this then brings to mind a reply to this thread that stated ewer errors doesn't mean there are fewer errors with the code. Please find below the errors, I hope this helps. Error (10481): VHDL Use Clause error at ringcounter2.vhd(2): design library "IEEE" does not contain primary unit "STD_LOGIC_1164" Error (10800): VHDL error at ringcounter2.vhd(2): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at ringcounter2.vhd(3): design library "IEEE" does not contain primary unit "NUMERIC_STD" Error (10800): VHDL error at ringcounter2.vhd(3): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at ringcounter2.vhd(4): design library "std" does not contain primary unit "standard" Error (10800): VHDL error at ringcounter2.vhd(4): selected name in use clause is not an expanded name Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings Error: Quartus II Full Compilation was unsuccessful. 8 errors, 0 warnings - Altera_Forum
Of course it would help if you said what error messages you got. By the way having fewer error messages doesn't mean there is fewer errors in the code, especially when you mess with something as global as library imports.
The second one is missing library imports and can't compile. I however don't see errors with the first one.
