15 years agoVhdl codes for 8-bit ring counter
Hi, I have VHDL codes for an 8-bit ring counter but when i try to compile it there are always errors (8 errors). I even tried editing some lines (lines 2 and 3) and compiled again and the erro...
15 years agoThanks for your help so far.
The thing is the (edited codes) codes without the library imports compiled and had fewer errors but this then brings to mind a reply to this thread that stated ewer errors doesn't mean there are fewer errors with the code. Please find below the errors, I hope this helps. Error (10481): VHDL Use Clause error at ringcounter2.vhd(2): design library "IEEE" does not contain primary unit "STD_LOGIC_1164" Error (10800): VHDL error at ringcounter2.vhd(2): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at ringcounter2.vhd(3): design library "IEEE" does not contain primary unit "NUMERIC_STD" Error (10800): VHDL error at ringcounter2.vhd(3): selected name in use clause is not an expanded name Error (10481): VHDL Use Clause error at ringcounter2.vhd(4): design library "std" does not contain primary unit "standard" Error (10800): VHDL error at ringcounter2.vhd(4): selected name in use clause is not an expanded name Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings Error: Quartus II Full Compilation was unsuccessful. 8 errors, 0 warnings
