16 years agovhdl-car park monitoring system
hi guys, i am new with vhdl and i have to write the following programm, the thing is tha i find it really hard and i would like some help. 1. The car park counts the number of cars parked insid...
16 years agoi also thought of adding a digital clock in the program in order to show the hour, minutes and seconds when the car enters or leaves
entity digi_clk is port (clk1 : in std_logic; seconds : out std_logic_vector(5 downto 0); minutes : out std_logic_vector(5 downto 0); hours : out std_logic_vector(4 downto 0) ); end digi_clk; architecture Behavioral of digi_clk is signal sec,min,hour : integer range 0 to 60 :=0; signal count : integer :=1; signal clk : std_logic :='0'; begin seconds <= conv_std_logic_vector(sec,6); minutes <= conv_std_logic_vector(min,6); hours <= conv_std_logic_vector(hour,5); process(clk1) begin if(clk1'event and clk1='1') then count <=count+1; if(count = 50000000) then clk <= not clk; count <=1; end if; end if; end process; process(clk) begin if(clk'event and clk='1') then sec <= sec+ 1; if(sec = 59) then min <= min + 1; end if; if(min = 60) then hour <= hour + 1; min <= 1; end if; if(hour = 24) then hour <= 0; end if; if(sec = 60) then sec <= 1; end if; end if; end process; end Behavioral;
