16 years agoVHDL 2008, DSP Builder and Quartus 10
Hi
I installed Quartus and DSP Builder v10 today and am already having trouble. In the sensitivity list for some of my processes in my hand written code I use the 'all' keyword, which apparently is only valid for VHDL 2008. From within Quartus I simply change the VHDL version in project settings and all is well. However I cannot now compile similar blocks in DSP Builder in Simulink (via the Import VHDL block) as I think VHDL 1993 is being assumed when Quartus is called to generate the SIMGEN stuff... as such none of my projects can now be compiled in DSP Builder / Simulink. Is there a way to set VHDL 2008 as a default in Quartus 10 or to tell Simulink DSP Builder v10 to tell Quartus 10 to use VHDL 2008? Many thanks, Kurt7 Replies
--- Quote Start --- this looks good for a Quartus II project, but i'm not sure that'll help in HDL Import in DSP Builder --- Quote End --- --- Quote Start --- Is there a way to set VHDL 2008 as a default in Quartus 10 or to tell Simulink DSP Builder v10 to tell Quartus 10 to use VHDL 2008? --- Quote End --- Not too sure about DSP Builder, but that's the way to do it if you want to set VHDL-2008 as the default in Quartus. - Altera_Forum
--- Quote Start --- Or, if you want to make VHDL-2008 your default VHDL version for all your VHDL files, you can add the following line in your QSF:
This can also be done in the GUI: Assignments > Settings > Analysis & Synthesis Settings > VHDL Input and choose "VHDL 2008" under VHDL Version. However, do note that not all VHDL-2008 features have been implemented. --- Quote End --- this looks good for a Quartus II project, but i'm not sure that'll help in HDL Import in DSP Builderset_global_assignment -name VHDL_INPUT_VERSION VHDL_2008 - Altera_Forum
hi guys anyboy knows how to implemente the SDRAM in DSP builder??
thanks!!! - Altera_Forum
This can also be done in the GUI: Assignments > Settings > Analysis & Synthesis Settings > VHDL Input and choose "VHDL 2008" under VHDL Version. However, do note that not all VHDL-2008 features have been implemented.set_global_assignment -name VHDL_INPUT_VERSION VHDL_2008 - Altera_Forum
excellent, this should probably go into the DSP Builder manual. i don't think the default QII VHDL version will change anytime soon (new keywords), so it would be useful to know how to control it manually
Many thanks indeed!!!
Adding: -- synthesis VHDL_INPUT_VERSION VHDL_2008 as the first line of my hand-coded VHD files worked perfectly. Kindest regards, Kurt - Altera_Forum
try the VHDL version synthesis directive:
http://quartushelp.altera.com/9.1/mergedprojects/hdl/vhdl/vhdl_input_vers_synth_directive.htm
