16 years agoVHDL - CASE related question
Hello, This is probably a very fundamental question but I'm a little confused as I am new to this. In VHDL (I'm sure it the same for others too), if I have such a PROCESS: PROC...
16 years agoThank you very mcuh Tricky, mmTsuchi.
Looks like a have long way to go. One thing that I can't understand is, A GENERATE block and a PROCESS block, 'how many' instructions can a FPGA perform? It ofcourse depends on the model, but as a programmer, how would you know that a block of code can be executed within a clock cycle? Or is it not like that? Is possible for a block of PROCESS to take several clock cycles to execute completely? Thank you.
