17 years agoVery simple question, first time using Verilog here...
Hello all... My name is Craig and this is my first post. I just started taking a course in HDL using Verilog. I've been beating my head against the wall for days over a very simple proble...
17 years agoHarald is right, you should do something like
`timescale 100 ns / 10 ns module obj_7bit_paritybitgenerator ( bus_bits, parityresult ); //Define the inputs/outputs for the circuit. input [6:0] bus_bits; output [7:0] parityresult; wire [7:0] parityresult; // maybe your parity bit must be inverted. assign parityresult[7] = bus_bits[0] ^ bus_bits[1] ^ bus_bits[2] ^ bus_bits[3] ^ bus_bits[4] ^ bus_bits[5] ^ bus_bits[6]; // question what about the parityresult[6:0] ??? endmodule But be aware that your parity is a wire and therefore could have some glitches. the next module should synchronize it to a clock. so always use full synchronous design whenever possible // always @ ( posedge clk ) // begin // insert your code here ... // end regards michael
