11 years agoVerilog/VHDL versus high level functions.
Im new to this, coming from audio programming in MSP/Reaktor and lower level assembler. So I have to learn a lot about the FPGA stuff as I go along. But two things came to mind. It was hint...
11 years agoA matter of preference. Verilog has enough sources online to get oneself to be proficient. VHDL would be a nightmare to start, due to the strict typing as mentioned by josyb.
By the way, functions and procedures are supported in Verilog-2001, and multi-dimensional arrays in system-Verilog (could be even earlier). Verilog as C-like would be an overstatement since if you write in C-style coding Verilog, high chances your code will not be synthesizable. Major difference is concurrency vs sequential, which most software programmers struggle with initially.
