14 years agoVerilog Synthesis Q
Am bumping into a synthesis problem inside of an always construct. Simplified code is reg true_or_false[0:9999]; reg a; always (negedge clk) begin if (a <5000) true_or_false...
14 years agoThe post mainly shows that's it's useless to show small code snippets. It's even unclear, if you have synchronous (in an edge sensitive always block) or asynchronous writes to reg decision.
I suggest to try it the other way around. Understand about the hardware features of FPGA internal RAM and the requirements of RAM inference from behavioral code. Then write your code considering these informations.
