14 years agoVerilog Synthesis Q
Am bumping into a synthesis problem inside of an always construct. Simplified code is reg true_or_false[0:9999]; reg a; always (negedge clk) begin if (a <5000) true_or_false...
14 years agoSorry for the confusion. Was trying to simplify the problem for brevity's sake.
Basically, I am capture the address bus on an old 80196 MPU using Cyclone 4 on a TerASIC DE2-115. Am using a NIOS II processor which preprocesses the 80196 list files to determine if a given address is a branch or not. If so, the branch offset is loaded into the TerASIC SRAM at an offset equal to the MPU address (so if MPU address 0x1234 represents a branch 0f 12, I store 12 at SRAM offset 0x1234). When a new address is available, I calculate the two addresses: one the represents the jump that occurs if the branch evaluates true, the other if false (I have to deal with a 5 byte prefetch on the false side). All of this synthesizes and fits quite well. My total logic element usage is 13% and my totoal memory bit usage is 53%. This 53% includes a 128k bit array that defines a true and false branch indication for each of the 64k addresses. So I don't think I'm running out of FPGA RAM due to the bit array. Once I determine that a given address represents a branch, I continue to collect addresses until either the true or false case is resolved. This is where I run into the RAM megafunction error. The code is in an always loop and looks like this (note branch_address is calculated earlier and is used as an index into the decision array): reg decision[0:128k-1] - Sorry too early in the morning to calculate 128 * 1024 - 1 if ((new_address > branch_false_address) && (new_address < branch_true_address)) decision[branch_address] <= 1; else if (new_address == branch_true_address) decision[branch_address+65536] <= 1 Adding this seeming innocuous code is where the problem lies. Am working to understand if it is the conditional logic statements or trying to set the decision array element that is causing me the problem. It seems that it is the conditionals that are causing the problem. BUt will confirm... Hope this clears it up some. Any more thoughts are greatly appreciated.
