14 years agoVerilog Synthesis Q
Am bumping into a synthesis problem inside of an always construct. Simplified code is reg true_or_false[0:9999]; reg a; always (negedge clk) begin if (a <5000) true_or_false...
14 years agoYour simplified code isn't very clear.
But from the looks of the message, you're designing something that requires a huge number of register (more than the FPGA has) and can't be converted to use SRAM. What you need to do is to try and re-write your code in such a way that it uses SRAM and meets Quartus HDL SRAM templates. See the HDL coding guidelines handbook for details.
