15 years ago
Verilog code to block diagram
Hello Folks,
I am very new to FPGAs/CPLDs so sorry if I'm asking something trivial but I am digging around the net for days now finding the answer to my problem. Unfortunately I couldn't find any tutorials or examples on how to make a new schematic block from a verilog code.
For example, I have a short code:
`timescale 1 ps / 1 ps
module SORD_PWM (Clock_In, Enabled, PulseS, PulseR);
input Enabled, Clock_In;
output PulseS, PulseR;
reg PulseS, PulseR;
reg ThresS = 200;
reg ThresO = 12;
reg ThresR = 200;
wire Enabled;
reg  Saw = 0;
reg Reset;
always @ (posedge Clock_In)
  if(Reset)
            Saw = 0;
  else
  begin
    PulseS = Saw <= ThresS;
    PulseR = (Saw - ThresO) <= ThresR;
    Saw = Saw + 1;
       end
endmodule
So how can I put this code in a block diagram that will represent a custom symbol, has wire connections, etc? It would be rather visual for educational purposes.
Many thanks
Best Regards
Tony
    • Keep opened this verilog file in quartus and go to
    --- Quote Start ---
    file-->create/update-->create symbol files for current file
    --- Quote End ---
    • Symbol file will be " <you current file name> . bsf".Then you can add with other blocks for connections.
    • You will get lines named "Enabled, Clock_In" at input side and "PulseS, PulseR" output side of the block.
