14 years agoverilog 12hour clock trouble
I am trying to design a twelve hour clock in Verilog to load into a DE2 board.
I have the seconds and minutes working just fine but am lost as to how get the hours to count properly. The way the logic needs to work is after decimal_counter_hour_0 increments up to 9, decimal_counter_hour_1 will increase its count by one and decimal_counter_hour_0 will return to a 0 on the positive clock edge showing 10:00. Because this is a 12 hour clock the count needs to be 10:00, 11:00, 12:00, and then start over at 1:00. I am lost as to how to implament the logic of this requierment. If you could give me a push in the right direction I would apreciate it. Thanks for the help. Below is the code to hours counters as they stand now. //This counter is the ones place of the hours count. module decimal_counter_hour_0(A,OVERFLOW,CLK,RST); input CLK, RST; output OVERFLOW; output [3:0] A; reg OVERFLOW; reg [3:0] A; always @ (posedge CLK or negedge RST) if (~RST) begin OVERFLOW <= 1'b0; //On reset a 0 from this counter is sent to the CLK input of the next counter telling it to hold its state. A <= 4'b0000; //On reset a 0 is is sent to the hex display. end else if (A<9) begin //If 'A' has a count that is less than 9 add one to the count on each A <= A + 1'b1; //positive clock edge. OVERFLOW <= 1'b0; //A 0 from this counter is sent to the CLK input of the next counter telling it to hold its state end //after the count has been incremented by one. else begin A <= 4'b0000; //On the next positive CLK edge after 'A' has been at 9, start the count over at 0. OVERFLOW <= 1'b1; //A 1 from this counter is sent as a posedge clock signal to the next counter. end endmodule //This counter is the tens place of the hours count. module decimal_counter_hour_1(A,OVERFLOW,CLK,RST); input CLK, RST; output OVERFLOW; output [3:0] A; reg OVERFLOW; reg [3:0] A; always @ (posedge CLK or negedge RST) if (~RST) begin OVERFLOW <= 1'b0; //On reset a 0 from this counter is sent to the CLK input of the next counter telling it to hold its state. A <= 4'b0000; //On reset a 0 is is sent to the hex display. end else if (A<1) begin //If 'A' has a count that is less than 1 add one to the count on each A <= A + 1'b1; //positive clock edge. OVERFLOW <= 1'b0; //A 0 from this counter is sent to the CLK input of the next counter telling it to hold its state end //after the count has been incremented by one. else begin A <= 4'b0000; //On the next positive CLK edge after 'A' has been at 1, start the count over at 0. OVERFLOW <= 1'b1; //A 1 from this counter is sent as a posedge clock signal to the next counter. end endmodule1 Reply
--- Quote Start --- I am trying to design a twelve hour clock in Verilog to load into a DE2 board. I have the seconds and minutes working just fine but am lost as to how get the hours to count properly. The way the logic needs to work is after decimal_counter_hour_0 increments up to 9, decimal_counter_hour_1 will increase its count by one and decimal_counter_hour_0 will return to a 0 on the positive clock edge showing 10:00. Because this is a 12 hour clock the count needs to be 10:00, 11:00, 12:00, and then start over at 1:00. I am lost as to how to implament the logic of this requierment. --- Quote End --- Hello. It is not that simple; while all other digits (minutes and seconds) can be done with the simple "Overflow" logic the hours cannot: The lower digit of the hour overflows from 9 to 0 if the higher digit is 0 but it overflows from 2 to 1 if the higher digit is 1. This means the counter for the lower digit must know the higher digit. There are two principial ways to handle this: 1) Use the output of the higher digit counter as input into the lower digit counter 2) Count both digits in the same module. This solution appears easier to me. Solution 2 may look like this (code shown here is NOT tested):
Martinmodule decimal_counter_hour(A10,A1,OVERFLOW,CLK,RST); input CLK, RST; output OVERFLOW; output A10; output A1; wire A10; wire OVERFLOW; wire A1; reg hour; initial hour = 1; always @ (posedge CLK or negedge RST) if (RST && hour<12) begin hour = hour + 1; end else begin hour = 1; end assign OVERFLOW = (hour < 2); assign A10 = (hour > 9); assign A1 = A10 ? (hour - 10) : hour; endmodule
