12 years agoVerify fail at reset vektor after adding PLL
Hi. Some days ago I've created a thread http://www.alteraforum.com/forum/showthread.php?t=42762 I think I asked questions wrong, however I can't delete it. So, my system was running at...
12 years agoHello and thank you for reply.
--- Quote Start --- You can use -90 degree clock to SDRAM clock. --- Quote End --- Why -90? I thought it depends on my hardware component. So if I use DE2-115 Board, according to ftp://ftp.altera.com/up/pub/altera_material/11.0/tutorials/vhdl/de2-115/using_the_sdram.pdf page 12, I have to shift the SDRAM clock -3ns with 50MHz. 20ns = 360° -3ns = 360/20*(-3) = -54°..... Is that right? I saw -90° in several sources, maybe someone con explain why. I'd appreciate it. Thanks. Vlad
