16 years agoVCCIO Voltage Change
Hi, I use EP3C10F256C8 chip , VCCIO set 1.8V , if other IO pin input set Hi(3.3V), result VCCIO change 2.2V? VCCIO set 1.5V , if other IO pin input set Hi(3.3V), result VCCIO change 2.2V?
16 years agoThank you for mentioning AN447. It's scope is different however, targetting to the said overshoot problem. So it effectively doesn't give new insights why the original Multi-IO feature has been abandoned I think.
