16 years agoVCCIO Voltage Change
Hi, I use EP3C10F256C8 chip , VCCIO set 1.8V , if other IO pin input set Hi(3.3V), result VCCIO change 2.2V? VCCIO set 1.5V , if other IO pin input set Hi(3.3V), result VCCIO change 2.2V?
16 years ago --- Quote Start --- I would ask support, if they can tell what exactly happens in this situation and if there's a risk of either device damage or temporary functional failure. I fear, you don't get a satisfying answer. Frank --- Quote End --- I filed a service request and the answer was only partly satisfying. There is a kind of multivoltage I/O application note for Cyclone III and IV. It is AN447 (http://www.altera.com/literature/an/an447.pdf) (http://www.altera.com/literature/an/an447.pdf%29). This application note however is limited to 2.5V, 3.0V and 3.3V I/O. Although I try to push him a bit, the application engineer advices to keep the input voltage below te recommended Vih,max. An overshoot voltage of 3.95V can be applied for 100% of the time over a 10 year period. I don't get any statement about what happens when I drive the input with a voltage between Vih,max and Vovershoot. Regards, Ton
