16 years agoVCCIO EPM7128SLC84-15 and 5 Volt outputs: HELP!
I'm using a MAX EPM7128SLC84-15 and need 5V logic outputs. So, the CPLD is wired with all VCC=5V and all the VCCIO = 5V too. Yet the outputs show 3.3V on the 'scope. I believed the Data Sheet page...
16 years agoYes, the external pull-up operation is rather slow, unless low, power consuming resistors are used. Are you sure, that you actually need high levels above 3.5V?
