11 years agoVCCIO and IO standard difference
hi, I have cyclone IV GX Device, VCCIO of the bank is 3.3V. However, in Quartus project there 2.5V standard as input and output setting. There is basicly 4 signals in that bank, 2 inputs and 2 o...
11 years ago --- Quote Start --- So, basicly the question is where does the IO standard has an effect in terms of -output pin -input pin ? -Tero --- Quote End --- Hi Tero: With the incorrect IO setting in quartus, the timing analyzer will not have the correct settings for the bank, and so your timing reports will be off. Also other cross checks will not be performed correctly (Like sso, input clamp warnings etc) Pete
