16 years agoVarible clock rate
Hello together I have a verilog-module that is working with an external 25 MHz clock. Now in my application I would like to work with a variable clock rate. Some other logic modules in the FPG...
16 years agoHello kaz
Wow, now it works fine. For others, that are interested in the working code, it looks like:
// Verilog module for variable clock generation triggering logic
// fOut = fclk * ClockGeneratorAccInc/2^32
// Accumulator increment value = fout/fOsc * 2^32;
// e.g. value = 19123456/24000000 * 2^32 = 3422275754
module DDS(clk, ClkEnable);
input clk;
output ClkEnable;
parameter ClockGeneratorAccWidth = 32; // plus overflow bit reg
ClockGeneratorAccWidth:0] ClockGeneratorAcc; always @(posedge clk)
begin
ClockGeneratorAcc <= ClockGeneratorAcc + 3422275754; // 19123456 MHz
end
// Use the highest bit of the counter (MSB) to enable clock
assign ClkEnable = ClockGeneratorAcc;
endmodule
// Example of use
// because ClkOut is toggeling we have the half frequency on output pin:)
module TestDDS(clk, fOut);
input clk;
output fOut;
wire cEn;
reg ClkOut;
DDS ClockGenerator(.clk(clk),.ClkEnable(cEn));
begin
if (cEn) ClkOut = ~ClkOut;
end
assign PWM = ClkOut;
endmodule
Thank you very much for your help again Geri
