arno_va's avatar
arno_va
3 years ago
Variable transceiver bitrate on a Cyclone V GX FPGA
We're building a custom transceiver application where we only use the transceiver's TX output. The FPGA's reference clock is clocked externally with a fixed 50 MHz clock for clocking the FPGA's trans...
  • AqidAyman_Altera's avatar
    3 years ago
    This is what feedback that I got from the internal team that I think worth to share with you:
    "If you adjust the REFCLK input to the Tx PLL, you'll maintain lock for some of the time, but the PLL settings may eventually become sub-optimal. Each data rate has a specific set of PLL settings. 600Mbps may not be the same as 1Gbps. One method you can investigate is to generate a MIF file for 600mpbs and another for 1Gbps. if the two are identical, you might be able to adjust the REFCLK input. However, we don't recommend PLL cascading for XCVR interfaces due to jitter concerns caused by core noise. Having said that, 1Gbps is pretty slow so jitter is less critical, it depends on the protocol requirements."
    Aqid
